'83 Cutlass Cruiser Build Thread
Been debating adding the vinyl woodgrain trim around the car once it's painted. Should I do it?
  • Yes, that wagon needs woodgrain
    Votes: 12 35.3%
  • No, leave that wagon smooth and simple.
    Votes: 22 64.7%
  • Total voters
    34
  • Poll closed .
12,177
9,779
Thank you, Blake!
I appreciate the information and will certainly relay it to him. So again regarding the quarter window sill mouldings, they'll pop off like a regular moulding, but then you'll have the studs to contend with, correct?
He wants to repaint the car, and of course remove any unwanted mouldings and such.
He also has the lower beltline mouldings on the doors.. those I believe are bolted to the doorskin, which entails welding the holes.
Blake442
6,864
1,997
Minneapolis
Yep, the 1/4 moldings pop off and then he'll have to remove the studs.
I usually just grab them with a vise-grip and twist them off... less grinding that way.
12,177
9,779
I like that method...it's less invasive, and safer than try to use a cutoff wheel.
81cutlass
4,649
13,565
Western MN
Nice!
Getting close to carcraft, excited to see it! :)
I might have dad bring the century wagon down too haha.
Blake442
6,864
1,997
Minneapolis
Finally got some pictures in the sun the other day...
Still need to go thru the brakes, get new front tires and have the alignment done.
Otherwise it's pretty much done!
Reactions: 15 users
liquidh8
Awesome! Looks good Blake!
81cutlass
4,649
13,565
Western MN
Dang that thing is nice. That single headlight header was a great choice, looks perfect on there.
12,177
9,779
The car looks great, Blake.
Hope you enjoy many years of happy cruising in it.
Ribbedroof
4,907
7,019
Wellston, OK
Careful, they have been known to make a hole in the panel that way. I usually use a roloc disc on an angle grinder to knock them down.
Car looks great!
