So an update here on the issue. My battery and alternator both tested bad, so i got kal tire to swap my battery under warranty, and partsource to replace the alternator...
Well, i installed everything and things didnt work as expected :/
In fact, i think i FINALLY figured out why the previous alternator went....
Because after installing the new parts, the alternator wasnt spinning, the fan was BARELY turning. So theres some real friction preventing the pulleys from spinning freely. The alt belt feels tight, but the belt behind it isnt. Revving the engine did nothing. Charge light still remains on with the motor running
The issue is i don't think i have the tools to remove the clutch fan to get to the belt
When the car had its water pump replaced and the alternator belt back in Jan 2017, an old coworker helped do the work due to my health conditions, and he said iirc the power steering belt should be replaced eventually.
Was too lazy to take a photo of my engine bay right now but heres a photo i edited to illustrate my point. The belt pointed in red arrows seems very loose as i said,doesn't even seem to have teeth to grip the pulley anymore..... Feels very flat rather.
I'm more familiar with the electrical side, so pardon my stupid question, but could the bad belt behind the alt belt (which i think is the power steering belt as previously stated) prevent the alternator and clutch fan from properly spinning? How do i tell if its the pulley or belt?
Is it possible to snip off the worn down belt to potentially reduce the friction, since the car wont drive anywhere?
I just want to see if i can get this alternator to charge my battery,so if it is the power steering belt causing friction, by the time I get that repaired at least ill have the charging issue out the way.
I'll post a youtube video later if that helps. Thanks for the patience guys!
