83MONTESS 496/8.5 build
-83MONTESS-
4,570
967
Bellevue, Ohio
GBodyscuffle said:
Dude I love the dash it looks absolutely awesome!
Thanks!
Well today was one of those days that made me wonder why I work on cars. I decided to address the broken body mount that is under the HVAC box. Here it is(was)
bad body mount 1 by bwollens1983, on Flickr
After I ripped that out I went to the one directly opposite of it under the brake booster area and found this. Its hard to make it out but the bolt head is gone...
bad body mount 2 by bwollens1983, on Flickr
I took a break and had a few beers. Then I decided since those mounts are ****ed why not try something to fix it. I cut a hole like this in both sides to get at the rotten cage nuts
bad body mount 3 by bwollens1983, on Flickr
Then I got the awesome idea of trying out my new radiator support bushings in those spots. I jacked the body up a little bit and the bushing slid right in.
bad body mount 5 by bwollens1983, on Flickr
bad body mount 4 by bwollens1983, on Flickr
I know that its not the correct way to fix it since the bushings I imagine are different lengths and whatnot but it works for now. I would buy the whole kit but the rest of the mounts appear to be fine so I will use these and then buy another kit for when I actually put the radiator support in. The rubber isnt cracked on the rest of the mounts and the bolts are all there and fairly rust free. Next winter I will probably do all of them.
-83MONTESS-
4,570
967
Bellevue, Ohio
Well I finally got around to the dreaded job of disassembling the front suspension. It went way smoother than I thought it would because I soaked every bolt and every joint in PB Blaster every couple days for about 2 months now. Got it ripped apart and found some weird stuff. First off my left front coil spring was broken. Im not really sure how long it was broken but back in high school I used to jump tracks leaving school so im thinking that may have had something to do with it :lol: Both shocks snapped apart when I broke the top bolt loose sending their oil EVERYWHERE!!! Upper control arm bushings were completely destroyed but all 4 ball joints appear to be fine as well as the lower control arm bushings. Im going to degrease everything real good, lay down some epoxy chassis paint and start the reassembly within the next week.
Here's the broken coil spring
broken coil spring by bwollens1983, on Flickr
GT_80
240
7
Massachusetts
-83MONTESS- said:
Im not sure if im going to be able to keep the corner cooling on the passenger side because of the distributor vacuum advance. The 90 degree fitting doesnt let the distributor turn enough it seems.
I had that issue with my truck too... I never used vac advance, but the can was still on my distributor. It always hit. I pulled the distributor and spun it one tooth to get more clearance.
You can kind of see the cooling hoses in this pic- This is a Professional Products Crosswing intake on a 1970 4bolt main truck motor.
-83MONTESS-
4,570
967
Bellevue, Ohio
Well I removed my brake booster to fit the hydroboost and everything fits good except the master cylinder is wrong for this pump. Which master cylinders can I run besides the ugly *ss cast iron monsters from the older models? Im not too up to speed on the differences in master cylinders. Any part numbers would be appreciated.
hydroboost fitment 2 by bwollens1983, on Flickr
hydroboost fitment by bwollens1983, on Flickr
-83MONTESS-
4,570
967
Bellevue, Ohio
Well I havent updated this mainly because I have been so busy between my 2 jobs and this project. I got everything cleaned with Purple Power and then painted it with some VHT Epoxy gloss black chassis paint. I also got the Speedway uppers, 2" Belltech drop spindles, and restored lowers installed. Should have the engine sitting in it later this week!
assembling front suspension 2 by bwollens1983, on Flickr
assembling front suspension by bwollens1983, on Flickr
drogg1
885
215
Lookin good so far.
That broken spring is impressive!
The speedway uppers, belltech drop spindles, and stock lowers are probably the route I'm also going. Have you chosen what springs and shocks you are going to go with up front? (Sorry if you have covered this somewhere else)
-83MONTESS-
4,570
967
Bellevue, Ohio
drogg1 said:
Lookin good so far.
Im using the Moog springs for the V8 Monte Carlos with A/C and just stock replacement shocks for now.
jfg69
19
Nice work on the chassis! How do you like the upper arms quality? They seem to look pretty good.
Sent from my SM-P600 using Tapatalk
-83MONTESS-
4,570
967
Bellevue, Ohio
The quality seems fine. Alot of people use these arms on the street so I trust them.
