thanks for the caddy links.i think i'm going to try a set of the 8.5 inch control arms.i've measured the 8 inch on there now and the extra .5 in. will bring the spindle about straight up.and i'll have room to add shims.as it stands now the center shaft is all the way to the frame with no room to shim it.i just thought of something...i've only seen the speedway arms on 81 and up g-bodies,i wonder if the 78-80's might be a little different.i'm going to have to look up the alinment specs to see if there's a difference.when i get a little further along i'll start a build thread.keep the updates coming.its good to see another ohio monte guy on here.
