Here they are. You have to order 2 right side ones because of the geometry.jfg69 said:Do you have a part number? I don't see them on Speedway..
Sent from my SPH-L900 using Tapatalk
Mine also seem to have screwed the camber all up. I bought them thinking they didnt require an alignment but oh well I guess.godlemmy said:cool monte.got to love the big cube motors,i'm putting a 500 cad in my 79 monte.first off i've got a question on the speedway arms. i ordered the 8 in. ones and they make the wheels toe in on top. are yours ok?both mine and my dad's 'bu both are toed in on top.i'll double check the part#sent,but would still like to know about yours. second,about your headers.the 'bu is getting a big block also and i think he got the same headers as you.we bolted the flange on the head down tight and heated the tubes by the head.then we slipped a log splitting wedge between the collector and the lower a arm mount.after letting it cool down by it self the wedge fell out.and presto plenty of clearence.we had tried to cut the arm mount but still needed more room for the collector.hope that helps some.
I guess I forgot to mention I have 2" drop spindles. The springs are the Moog replacements for the car with AC. I still have the front end and the hood to put on so im hoping it drops it alot more.pontiacgp said:The springs won't break in to lower the car. If you just dropped the car off the jack stands it will sit higher until the front wheels roll on the ground. When I was cutting my springs I cut them a little longer than I wanted and drove around for a week to see if they would settle. They didn't loose any height so I had to trim them again.
