Trans parts showed up Friday and I pulled the trans today.
Contacted the local T56 rebuild guy and he said he's too busy to have the leadtime I need so I am tacking this one myself.
Rear housing off!
The 5/6 driven gear is supposed to be a press fit.
Some people say they slide off easy, some people say they need a lot of force to pull it off. Mine slid off and exposed some noticeable spline wear. Not sure what to think. I'd need a replacement main shaft to fix that one. Not sure if that means problem or?? I don't plan on WOT 5 or 6th gear loading so it's not going to see a ton of load. People do claim they get vibration if the interface isn't tight.
One of the problem gears was reverse. It's tough to pull into gear. I assumed the blocker rings were worn but the tips of the syncro sleeve ring look pretty bad. Not sure if that is due to the blocker rings being worn or the clutch dragging or??
Figures they are out of stock.
T56 Reverse Synchro Sleeve Fits all 92-07 T56 units & 96-00 T45 units Interchanges with 1386-509-004 & 12523043
txdrivetrain.com
The reverse gear is better but still iffy
And fully down
I still have some mainshaft disassembly to do, Im pretty sure I need to press the 1/2 syncro drum off the shaft so I need to get my press out for that.
Blocker rings look fine I guess?
For sure some goop inside the cavity
I also ordered a replacement 2nd gear because they say a newer 01+ viper spec one is wider, mine is a 97 and the same, so either I got a narrow gear or mine already had the wide one? Or I ordered the wrong thing?
Oh joy
