Seems like a lot of updates lately but the car is finally getting to the point where it's a serious daily driver.
Coming back from the goodguys show Saturday there was a huge storm. Was planning to camp in town Saturday night but about 5 inches into the rainfall total we decided to bail on that and drive the 130 miles home. Was at the center of the 10" area.
So, ended up trying to dodge the puddles and get outta town. Didn't want to sleep in the car.
Worse thing was I found my rear window leaked. Not a drip, like a steady stream. Spend most of the day yesterday pulling the rear seat out and drying the carpet. There was around a gallon of water at minimum back there. Not sure if the window seal finally opened from the autocross or what, but its the first time I drove the car through a serious rainfall.
On a more positive note- Got my cruise working! Super easy with DBW like I have. I had hooked it up about a year ago but never could get it to turn on. Probed my wires and it should have worked, but didn't. Ended up missing 1 wire and had incorrect resistance on 1 wire. It takes 6 wires. 3 for the cruise, 1 TCC lockup, 1 brake light signal (that needs to see resistance) and a ground. Did some reading and found the ECM requires a "not in park" ground signal on pin 32 blue to work. Would be fine if I had a 60e or 80e, need it for anything else.
Also, the light blue 3rd brake light wire that is claimed to be able to just be spliced in to the brake light wiring that sees 12V when the brakes are applied needs to see around 8 ohm. I only had 4 ohm and it would not turn on. I added a 4 ohm resistor and it worked. Had to ask my electrical engineering buddy to take a look at the wiring diagram off the 01 silverado to explain to me the logic of how it worked and where I could put the resistor. I will have to make a diagram of it sometime and make a how to. Took about 20 different internet links to find what it needs. Should apply to 99-07 DBC or DBW ls stuff.
