I have been swamped wrapping up college. At least im a gadjeate now. Off for a few weeks before I start my new full time job so between moving Im getting a little done.
I make a little progress and loose a bit. Constant fight for little stuff.
I had a hunch the lack of oil pressure senor signal was stopping the TB from moving. Also wanted to get some knock sensors in there so I picked up the sensors, harness, and oil pressure sendor. Didnt have a socket to fit the big sensor so had to make one and proceeded to break the damn sensor in half. Got mad and let it sit.
Also the knock sensor harness doesnt fit between the valley cover and intake so I gotta mill a slot in the cover for the wires. Argh.
About a month later (now) I had time so I put a new oil pressure sender in. Its plugged in but HPT isnt reading signal. Im not sure if HPT reads signal on it or not. I dont think it ever did on my 3800. Might be a bad sensor or something I dont know. HPT reads like -15 PSI.
Semi good news is I got my steam lines in. There wasnt an aftermarket kit I saw that worked so I built some compression line stuff. 20 pounds of boost and some copper line?
There was nothing factory or anything I could find that would do a 4 port bead port setup and fit under the blower manifold. Hopefully it lasts. The magnusson front only line was like $120 and I said no way to that.
I tried starting it and my fuel pump didnt turn on. Was going to return it but took it off and put voltage to it on the bench and tapped it and loosened it up. Thankfully it works again.
Still dont have working pedal. As soon as the engine gets crank signal the ECM stops reading the pedal. I hooked HPT up and the pedal outputs 0-175% throttle for some reason. If I start the engine with 25% (or whatever) throttle as soon as the engine starts the ECM reads the pedal at 0% regardless of the position of the pedal. The pedal is getting 12V source in the harness weather the engine is on or off and the 5V circuits on the pedal are the same engine running or not.
Im really close to buying a DBC harness and DBC TB and scrapping this harness. Theres no support for DBW stuff and nobody has a clue what is causing this. There is something with the ECM weather in the tune or missing sensor that ignores the pedal with the engine running.
