Fturd is sitting at Dads place back home.
if I still have a car running on the road at that time I think it sounds like fun.
I had to order some speedo and trans TC LU parts for the cutlass so I finally spent money on on the roof rail weatherstrip for this. I gotta get the door seals still but my room mate is going to pull the motor on his fiero in a month and wanted weatherstrip in this so it can sit outside.
Anyways, the options are soffseal or metro since GM NOS stuff is stupid expensive and I really doubt people going straight to "its junk" conclusion.
Ended up going it metro since they are generally reviewed as being better and from MN so thats cool.
I only got the drivers side in, goes into the grooves super easy. Had to adjust the window (obviously, I think most of the people think you can take a wore out GM 30 year old piece of rubber and put the replacement stuff in and it fits flawlessly) but overall its decent. Door closes tough but the door striker is shot (plastic bit in between bushing and ID) so Im blaming it on that right now. Seal fits straight, door just closes bad. There is some wiring gremlins like the passenger switch not working at all, wires being very loose on the drivers window switch, drivers switch occasionally works and only lets the passenger go down, not up, blows the circuit otherwise.
Probably piddle around with wiring tomorrow and get the drivers striker replaced and get passenger seal in.
