Put my big boy pants on and found my motivation to work on instrumentation. It was a high of -3f today and the new garage heater does get the air to 55 but the concrete is still like cold soaked to 15f so it's not a lay on the concrete day.
Went to the weird electronics surplus and salvage store and got some rocker switches and relays and holders Friday after work.
Switches will make the 2 temp and 2 pressure sensors feed into the one remaining input for temp and pressure I have left on the factory pcm. I'm using the ac pressure input for the clutch and fuel sensors and the trans temp sensor for the pre and post aftercooler sensors. I dug through my pinout options and found 4 5v signal supplies in the pcm so I tapped into those to supply the pressure sensors.
Relays and holders are to offload the e-fan relay out of my main fuse box. I have usually ran both of the intrepid fans off one relay but have had one or two instances of the fans randomly stopping and engine overheating, and never could replicate the problem until Drag Weekend last fall when I determined the relay was getting hot. 1 relay and all the current was too much and heatsoaking. I unplugged one of the fans and that solved it, but I never hooked up my other fan to turn on with the ac on and plan to turn on the 2 fan outputs on the pcm so I'll flip on one fan at like 180 and the other at 210 or so and also trigger that with my AC. It only happened when hot, in traffic, after a long cruise at highway speed and then only occurred maybe 3 times in the 5 years I've had the setup together so it took a lot of under hood heat combined with the fans being on for a long time to cause an issue. If I didn't do a drag week style event I probably would have never encountered the issue really.
Parts!
You might be able to see the one wire near the right side, that's the fan power out wire, it got hot! Yikes! insulation burned and flaked off. Could have been a fire for sure. I'm isolating this one for good reason.
Notched the FPR bracket for the fuel pressure sensor and used a 1/8 street elbow to clear the filler neck.
And I was making ok progress and went to my phone and pulled up marketplace for a minute and saw this arbor press for $40 posted so I snapped that up.
It's going to be under -20F tonight and -8 as a high tomorrow so I'm probably going to do some work inside and push off anymore garage work until the high is above zero since I have to do some under car work on the wiring. At least I have a plan and am pretty sure I can set everything up as desired.
