BUILD THREAD 86 GP 2+2~Blown 6.0
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
Red Deer, Northern Montana territory
If GP403 didn't want me to use it, he shouldn't leave it out where I can find it.
PS. Look up "butt" in the GIF, there is some good stuff waiting in there.
rocket power nicksplat GIF
I was today years old when I discovered we had gifs built into the forum.
Here i thought Mike just had fire internet skills....
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
motorheadmike
8,976
27,522
81cutlass
4,649
13,565
Western MN
Getting back on track....
thomas the train GIF by Bleed Gfx
Spaghetti was for dinner. Got smart and realized the intrepid fan I have has a high and low speed so I can use the fan 1 output on the pcm to run low and the fan 2 output to run high. I've always just ran both off 1 relay on high and that overloaded the relay. I also decided to put a switch in the dash to turn the fans on manually if desired.
I built a little panel to hold the relays, the third is for the clutch solenoid valve which still needs to be done.
I'm out of wire butts (har har Gifs....) And heat shrink so I gotta run and get more of those and I can wrap this up.
64nailhead
Goat Herder
Dec 1, 2014
5,709
12,216
Upstate NY
Please explain the Intrepid high/low speed setup?
81cutlass
4,649
13,565
Western MN
The intrepid fans are dual coil so if you apply 12V to the dark green wire they spin slow, and then if you additionally add 12V to the yellow wire, they spin fast.
Reactions: 4 users
