Spent part of the evening last night realigning my drivers window. When I changed my body mounts the drivers door went out of alignment, which then put my window out of check. No photos, just 2 hours of loosen bolt, move tab 1/8", tighten bolt, close door. Repeat.
On today's topic of changing things that probably don't need to be changed-
I built a lot of the fuel system on this car from parts I ordered off Pro Products when they had a closeout sale. Regulator, a lot of the fittings, filter, ect. It's been fine for 4 years.
The filter I used is a small -6 inline one and the size (and filter rating) concerns me as it's literally not stated. (This one linked) Plus, it's not really serviceable and they claim it's only good for prefilter and up to 550hp and since I am on E85 AND about 550hp I think it's too small. Plus I have been watching some youtube videos and seeing stuff online of injectors sticking and am concerned about fuel cleanliness so time to do something about it.
<h3><span style="color:#A80000 ">Fuel Inline Filter -6AN -Polished</span></h3> <p><strong>This high performance inline street filter in polished aluminum is basically the same as the 10210 and 10211 models shown above. These filters are equipped with a -
professional-products.com
Since I am more of a farmer and off highway industrial equipment design engineer than a race car builder I thought I'd look at the fuel system like a 1983 JD 4440 and move to cartage style filtering.
Baldwin (parker hannifin) makes a nice fuel filter mount that I am going to mount to my trunk pan between the fuel tank and the rear end. It's also -12 ORB port on both sides so no crappy NPT ports that seep and cartage filters mean I can spin a new one on instead of dumping fuel all over my arm with those paper element ones.
Baldwin Fuel Filter Bases convert a cartridge style filtration system to a spin-on style system.
ph.baldwinfilters.com
And A WIX 33107 is a easy to get part from any NAPA for $10, has a 10 mircon rating, and should flow what I need.
So stuff is on order.
