Nice improvement. There is a tool for the spring. For next time or for others....Do daily diddly squat updates annoy people? I guess here's another one.
Anyways, this car has never had functioning door hinge detents. The hinges on this thing were wasted when I got it. Miles of endplay from worn pins and the detent rollers were siezed up so bad they were literally ground down into D shapes.
I cut the detent pins off and replaced the hinge pins back in '15 and ignored the detents. Honestly I should have just bought new hinges but I was a poor college student at the time.
I continually forgot to rob a decent set of detent pins off a junkyard car and I kinda assumed they'd be junk anyways. Classic Ind makes replacement detent pins for A bodies and it's semi reported they fit G's with some mods and now that I have my lathe it was a perfect excuse to deal with it.
I had to turn the diameter where the screw threads in down to 0.310 from like 0.425". I think A body hinges are taller so I just made this pin so the top slides into a hole that is left from the stock detent pins.
I also had one of the bushings disintegrate in the drivers upper hinge so I replaced that with a spare I had floating around.
Getting the springs in was kinda a beotch. Drivers side I had the door side of the hinge out to change the bushing and I just jacked the edge of the door up with my floor jack to compress the spring and then inserted the pin.
Pass side I had to compress the spring with my bench vise and used 3 zip ties at near full compression and then a lot of cursing, wiggling, prying and some luck to get it in.
So yes, A body detent pins work on a G with minimal mods. A grinder or hacksaw would work to make the pin slightly shorter.
And results, the detents do help close the door and makes them less floppy which is a nice change.
Turned modified pin left, replacement right
Pretty much.Is that your roll center axis?
That would have helped significantly!Nice improvement. There is a tool for the spring. For next time or for others....
I can't imagine doing the job without that tool. You've got a lot of ingenuity.That would have helped significantly!
Ingenuity is just another way to say too poor of a planner to order the tool, too impatient to wait, and too stubborn to buy it in the first place
I was away for Easter so I spent some time sitting on the couch with my laptop looking up tune things. I have 3 main problems I wanted to solve
1. My cruise doesn't work. It used to! When I had my 01 PCM I found an operating system on a Firebird with a t56 that I could swap all the t56 related info into the 4l60e sierra tune. My issue is when I went with my 02 Tahoe flex fuel enabled PCM I lost cruise. I found the PCM does an internal check where it looks at the engine RPM vs the VSS and if it's OK it allows cruise. I assume that's in case the vehicle is on ice, the trans is going out, or some safety related thing. I found out some people have the issue when they try swap the 1st gear planetary with a lower numerical ratio and their cruise won't work in 1st gear anymore.
The solution is either find a t56 tune with an OS# that can plug into the 02 Tahoe PCM (which doesn't exist, there is no t56 data that you can stick into a P01 flex PCM at this juncture) or change the gear ratios in a 60e tune to make it THINK it is a t56. Thats what I want to do. I would basically take 1-4th on the 60e tune and make it 3-6 t56 ratios.
The table convenient exists in this random F body tune
But my luck, look at my tune, the damn thing doesn't exist!!!
I at least found my issue. I have a request out to HPtuners. They replied back with the basic tech support stuff and said make sure you have it in advanced view (which it is), make sure you have the most up to date version (it is) and to do a debug scan and send it to them. I know they are doing their diligence for people that have simple issues, but I can see the damn table, they just don't have it enabled on the flex tune to change.
I have somewhat low hopes they will add the table to my flex OS but here's hoping.
So a segment swap is out of the question?
Yup. I asked HPtuners a few months back if they are aware of an OS that allows flex and t56 segment swap and they said no.
I took the car for a cruise tonight and besides blowing both fan fuses (apparently 20 amps isn't enough for low or high on an intrepid fan) everything is still good. I just needed to get over 30mph and it got enough air flow that it self cooled. I threw a 25 and 30 amp in the low and high to see if either helps. I think those little fuses just don't have the amp rating for quick high amp draws when they turn on.
Maybe it's just confirmation bias but the front end actually rides better with these foam bump stops. Before I bottomed the suspension out relatively easy and I knew when I got a big bump. I don't feel that harsh hit anymore which is a win. Honestly I think I'm putting those foam ones on my Cutlass this winter as long as these hold up on this car for the summer.
