I think I meant to say Key Off Engine Off on a timer for that circuit. It was pretty early when I wrote that.
That said... its a shame you don't live closer we could get up to all kinds of wacky stuff.
It's a 3/8 air hose on a 2" muffler clamp as a intercooler pump mount.
I hope your radiator isn't leaking. I also hope it isn't something worse. A plastic kiddie pool might be an option for testing. Amazon has inflatable ones for less than $20. You might find a hard plastic one locally for less. I saw one used as a parts washing tub in one of the build threads.Spent last night trying to hunt down my slight coolant leak from the radiator area that has started sometime last summer. It's minor but with the dog around and a few neighbors, plus getting flack at the track I wanted to get it fixed.
Texas82GP mentioned his brother's Griffin LS radiator developed a leak shortly after install. That got in my head and now I am worried.
I pulled the rad last night and looked for a pin hole, crack, or something that wore through on the bottom near the mounts and didn't see anything. My rubber isolators weren't ideal but they seem that they are doing what they need, no scuffs. I put a Schroeder valve in one of the steam vent ports and filled it with 5psi and dunked the bottom and each side of the rad in a tote full of water to search for bubbles, nothing.
I put the rad back the car and hooked up both hoses. I filled the entire cooling system with 15psi last night and it had 8psi this morning. I do know I have a leak, but I can't find it. Argh. I might sneak the rad into the house and use the tub tonight. I don't have a tote large enough to hold the entire thing at a time.
In less frustrating, hopefully more beneficial news, I am getting into suspension refinement now that I am happy with my rear ride height. Turbo John has a good few videos on instant center explanation and what a radial vs slick car should behave like.
Basically for the last 3 years I have three problems on my launch. I either spin, bog, or light tire shake. When it light tire shakes it actually goes the fastest. It's knife-edged between spin or bog. My two step has helped immensely, and I hope my clutch delay valve will be beneficial. However, I assume I am going to (at best) end up in the zone where it tire shakes if I adjust it so the engine doesn't pull down or just overpower the track.
I got a quote from a local guy who is a dealer for a pair of Viking Warrior shocks ($385). Double adjustable nice ones. I was hoping for a bit of a discount over list price (it really isn't) but it is what it is.
I have those used comp engineering shocks for the front, I think I am going to buy a set of adjustable rears and put those comps up front to slow down the nose drop on shifts. See how that helps.
Tire shake is DEATH to your driveline. It doesn't matter what you have for driveline components - at some point it will break stuff. I know you've seen this, but you have to tune out tire shake. I'm not 100% on whether it is the diff shaking, tires, axles or a combination of all of the above. But I know the result - shock load.
I believe, repeat believe, that being able to put the load onto the diff once it hits the instant center and being able to maintain the load consistently should eliminate it. But WTH do I know lol. I've experienced it as well and when I do I immediately dump the the throttle trying to keep my junk in one piece.
Once you get your driveline angle correct (maybe it's good now), then it will be in your rpm (boost) being ramped in to control the power until you get it moving to stop the shake. I know I've shaken the tires when I have put too much timing in on the hit. Dialing back the hit is the hardest part of my tune and I'm yet to get it right. Once I do I will be happy. And I believe you're in the same boat - and yours is much more difficult IMO because of both the stick(T56) and stock ECM.
My advice - don't hurry and break sh*t - drive it, enjoy it, go FAST
Can you retard the timing when launching and feed it back in after clutch release or 2 step release? Possibly with a different tune, i.e a street tune and race tune?
