BUILD THREAD 86 MCSS - Rejuvenation Project
Rktpwrd
Builder of Cool Shjt
4,181
23,998
Calgary, Alberta, Canada
Yes, they're both normal and OEM. Check the cracking sealer around the HVAC box, they're often the culprit in mystery water leaks inside the car.
Gozer442
281
259
Ontario, Canada
I had a battle with the distributor hold down bolt.
Is this coating on the firewall original or was it applied later on? There is cracking of the sealer at the left side of the HVAC box. What about that ground braid from the middle of the cowl, running behind the trans dip stick and going into the HVAC box seam - normal?
That ground braid attaches to the heater core in the HVAC assembly.
And glad to see there's SOME dirt buildup found on your car(firewall)! ;););) J.K.
I'm blown away at how clean that car is!
Opie Knievel
Sep 6, 2010
1,512
1,859
Brodhead, Kentucky
Doing his research, looking the cars over really good, not buying the first one you see, all of these paid off. He found one of the cleanest G Bodies I've seen.
ed1948
1,286
1,613
Quinte West, Ontario
Re & re'd the distributor, checked, cleaned, shimmed and a quick polish.
before and after:
ed1948
1,286
1,613
Somebody wasn't in a good mood to change instrument bulbs I guess.
JB Weld to the rescue.
7,990
18,710
Any updates?
ed1948
1,286
1,613
'Overhauled' the instrument assy and repair careless previous service attempts. JB Weld comes in handy. Shimmed the foam seat base bun
7,990
18,710
Nice repair work on the binnacle. Would you care to elaborate on the seat bun shimming? (what you did and why)
ed1948
1,286
1,613
I found the seats a bit too soft and saggy. I posted the details of the seat refurb on the Monte Carlo SS forum. Basically I shimmed the bolsters with slit 1/2" pipe insulation placed on the metal frame rails and placed carpet remnant under the base and adjusted the wire basket(shortened the wires) for higher tension.
...and I lubed the trip meter reset assy. The orange bevelled slider thing, black plastic plunger and the number shaft.
ed1948
1,286
1,613
Next is the console lid. The plastic under the pad is cracked in several places.
and the pad itself does not fit nicely..stay tuned.
