BUILD THREAD 87 SS, 305 is the one who knocks
5,717
12,236
The buckets need nothing. The issue is that the plugs are not wired the same - you have to move pins around on your factory plugs. The ones we have are in a molded plug on the light, so no swapping pins to match the factory stuff, and add the turn signal wire into it. After that, it was easy.
5,717
12,236
We have the halos as turn signals - they are yellow, not white.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
Cool. I currently have Sylvania 1157 amber LED's in the Cutlass, but curious how the switchbacks do. I already have the E flashers in.
  • Love
they are now only amber when i put the turn signals or hazards on.
I just had a shocking revelation. Thank you!
Basically, I will forsake my inner parking lights for DRLS. I'll still have the outers and sides that line up under and around the low beam/outer headlight. Inner under the high beam becomes DRL and turn. Done deal!
79MaliCrazz
577
70
Lake Wylie,SC
Great job bro looks good
jakes87SS
506
1,330
ohio
so here's one more thought if you got headlights with halo rings like ones i ordered or something a bit cheaper you could take the white drls that turn amber on turns
take this kit, from digitalis plug it into your turns and use it to sequence the halos and turn signals in the front of the car to blink sequentially too. i want to do this but i want to be able to use my colored halo rings as well. haven't figured out how to have both yet.
