It probably couldn't hurt to try flushing out the calipers before plunking down cash for reman'd units. You can always use them as cores if need be.
As for the hubs, you'll have to remove the calipers and rotors in order to check how they spin.
I think I may be lucky as far as the bearings are concerned. They are quite pricey if you haven't noticed.
I haven't installed mine yet, however,I have also found that the caliper mounting brackets are worn and will need to be replaced. I think at that point I will replace the calipers with new brackets.
As for hardware, there really isn't much aside from banjo bolts for your brake hoses and sealing washers. If your units are complete as pulled, the backing plates will be in place with the bolts...and also the caliper bolts. Of course, you will have to check the condition of your hardware.
