Wow, that all looks really good.
So let me set it straight. You CAN use either (S10 or Blazer) but it is recommended to use a regular Chevy "Blazer" for the dual piston setup. I will purchase the following
Junkyard = Spindles & Dustcover from the Chevy Blazer.
Auto Parts Store = Rotors, Calipers, Hub Assembly, Brake Pads, DOT 3 or 4 Fluid
Is there a modification that needs to be made to utilize the C5 Caliper & Rotor upgrade on the blazer parts?
Thanks,
Martin
The s-10 and blazer are different but front end looks the same. In 98 chevy made s10 designation fir the pick up and blazer for the suv. Before 98 it was s10 pick up and s10 blazer.
So you will need 98-05 2wd blazer spindles set up with the dual piston calipers.
Kore-3.con has the brackets to adapt the c5/6 calipers without mods. Some vettes had the z51 package that has 13.5 inch rotors which require18"inch wheels. Base c6 and base or z06 c5 vettes have the 13 inch rotors but require at least 17 inch wheels. Kore 3 had a template to check for wheel clearance.
With the blazer wheels you can run most factory 16 inch wheels and some 15 inch wheels.
