Ok I got a leakdown tester on order today about 1230 and it showed up at my door at 630 when I was making dinner, dang Amazon... I'm impressed.
I wanted to work through the service manual no start flowchart and cross everything off that list.
I noticed my crank sensor was really loose and really dirty. The crank sensor is really hokey on these.
There's some little rubber isolators inside between the plastic sensor and the aluminum bracket and they were almost falling out. There was also a lot of iron filings sitting in the gap probably due to the fact that it was sitting under my workbench or at a full time turbo fabricators shop for 18 months and and metal dust might have floated up and stuck to it.
Cleaned up the sensor and reset it and no change. Still miss on 1&5.
Went through the rest of the no start flow chart and every time it goes back to the ignition module being bad.
I also posted a quick question on the turbo Buick forum and I've gotten a bunch of comments to change the cam sensor cap. I have an adjustable Casper's LED cap to aid setting and the OEM one I had was bad so I bought this as a replacement because it's the only one available. According to multiple people they aren't good and cause misfires. I need to hunt down a OEM style cap.
I also leakdown tested and although it's not great news it's not bad.
Cyl 1- 25%
Cyl 3- 2%
Cyl 5- 11%
I didn't get a chance to check the passenger side.
I'd say half to 2/3 the leakage air in cyl 1 was coming out of the crank and 1/2-1/3 out the intake. I think the cyl 1 intake valve is hung or not seating well. Its probably contributing to the backfire if In fact the ignition module is shot and it's sending good spark but it's poorly timed.
Im supposed to get the new ignition module tomorrow so I'll toss that in and see what it does.
I also had fuel on the plugs this time now that I just cranked it and it never really started so I'm beginning to think it's boiling down to the ignition module not controlling the spark and telling the ECM where the cam is to fuel at the right time.
World's hokiest crank sensor that requires adjustment too.
Cyl #5
