Got the rest of the dash together tonight.
Fixed the power steering pump whine by topping off the resovoir. Kinda embarrassed I ordered up a pump and didn't check fluid level first but at least I didn't spend the time changing a good pump. All im out is return shipping. Like I say, it's important to proudly wave your idiot flag when the time comes.
Fixed the blinkers by connecting the ground wire at the header panel and wiggling a tail light bulb.
Took it for a drive and the tach and speed signal work.
Coolant temp is only 155-165. It was cool tonight but I need to check the tstat and go up to a 180.
Overall drives really nice. Trans feels like a rubber band at mid throttle and it feels like it doesn't know what gear to be in, CVT like. Its fine at under 10% throttle and ok over 50% throttle but it builds say 0-5 psi at 25% throttle and the engine sounds like it's revving pretty decent but the trans doesn't really do anything, and I can't much tell if it's not at the shift point, slipping or normal and just making so much intake/wind noise I can't tell. Its a stock 88ish
caprice takeout with nothing more than a cut down governor and a GN D5 converter so I can't complain to much.
I did pick up a sonnax servo that I'm planning to swap and see if I can sneak in a bigger boost valve without pulling the entire trans to get me through the summer before I totally toast what's left of the band and direct clutch.
It makes 12 psi and the AFR is 12.9-13.2. The scanmaster is picking up more than just a tickle of KR and I could hear a bit of detonation out the window so i know it's real. I haven't done anything more than a very limited number of short WOT blasts. Its got 91 so it shouldn't detonate at only 12 psi but it's a bit lean and I have zero idea what the chip has in it so I'm going to lay off the throttle until I get data logging capabilities.
Car is really quiet, like 75% of the noise is just intake and turbo.
Its ready for daily/cruiser status though!
