Todays update is "The Good, the Bad and the Ugly"
I was wanting to do an LS swap in the wagon but just don't have the time right now.
The 305 I had expected to last maybe 3-4 months before blowing up had now lasted 2 years of just so much abuse (overheated a couple time, foot to the floor all the time, old used motor oil since it burned through so much. I have much more respect for 305's after actually having a car with one it it because it was damn reliable and had enough power to pull the wagon on 11.00 flat run after run in the 1/8mile. That was until it ate a cam lobe completely off, so my brother had the great idea of sticking a nut under the rocker arm to keep the valve open to prevent fuel buildup. So we did that and I continued to drive it 3000 miles more! Never did give me any problems on all those miles except for the sound of an obvious miss. Bravo 305, I never did end up killing it before pulling the motor out.
6 months ago
So I decided on just going for a mild built 350. Found a vortec 350 motor from a guy on Facebook market place who owned a junkyard, got it home and pulled the pan and it was just filled with massive shavings. Pulled the bearings and they were completely wore out and I decided not to look any further since the junkyard had a warranty on the motor. I knew I could do a bearing kit but didn't feel like finding our later that metal came from something else other than the bearings.
Just a little adventure on getting another engine, feel free to skip this next part
5 months ago
Looked around on Facebook market place a bit more and found a great deal. $300 supposed running. Got there and talked to the guy for a while, the motor had some longtube headers, holley contender allum intake, nice ACCEL distributor, all the accessories including serpentine setup. Pulled the valve covers and got met with some milkshake (great drove 90 minutes for this). Told him ill give him $200 since he said it was running, expected a $250 counter offer but he actually took the $200! There was 3 amish people there hanging out with this guy so all 5 of us loaded it into my Ranger. Set the motor down on a tire, put 3 ratchet straps on. Talked for a long while with everyone and the Amish were quite interested in what the motor was going into, and also my schooling since it was related to National parks. Really nice folks. Hit the road back home around 10:00pm.
On the trip back I was taking turns slow on the back roads and just before getting on the high way I hear a bang after going around a turn. I look behind me and see the motor has fallen over. I pull into this parking lot right under the one and only dimly light light posts and find our one of my ratchet straps broke (my fault I didnt put them in a good spot so it was top heavy still). I decide I have to get this motor set back up since its in a position to roll around in my bed now. So now Im left with my phone on 4% and I cant charge it while the trucks not running because my battery was trash, a barley working light post for my illumination, and a motor that is now leaking this milkshake of coolant, oil, and (maybe) motor honey all over the bed of my truck and soon to be leaking all over the parking lot. Thinking to myself there's no way for my 150lb self is going to move this 600lb block of metal back onto the tire. So i get to work strategically moving and using the ratchet straps around to slowly crank it back up and into position. I finally manage to get it back up and strap it down extra good (this timing using all my straps). Finally got back in my truck and made it the rest of the way home with no troubles a little after midnight.
Further engine inspection
Pulling the pan off it revealed the motor to be a 4 bolt main (010 block) , a welcoming sight. the bearings were fine, but 2 of the cylinders on one side were filled with coolant, and had scorched the walls a bit. From what I can tell is they rebuilt this motor and didn't know what they were doing and started it up and then the head gasket didnt seal and it spewed coolant into the cylinder and that resulted in the milkshake. This assumption was made because during the tear down lots of the bolts weren't torqued (some where barley hand tight, others had to uses the impact to get off), and just tons of mismatched bolts.
After doing some more inspecting the head on the side of the coolant leak had cracked in-between the 2 exhaust valves. Cant catch a break.
I was still able to sell the set of heads for $100 since they are apparently good for circle track racing (forgot the casting number) to a local guy I know. Then found a set of aluminum '113' heads (on Facebook of course) with screw in studs for just $300. Got some vortec valve covers from the junkyard to match.
Engine building
Took the engine and crank to Allison's Machine Shop in Asheboro, NC. They do really good work, my family has taken lots of things there to get machined. The block got bored out .30 over because of the scorched walls, and the crank got polished. and they had the entire engine block cleaned.
I've painted the engine block ford blue upon its return from the machine shop. Don't judge my decision on the color I just though it would be funny in some type of weird way.
No clue why the Holley contender intake was painted, and so terribly at that so I had my brother take it to his work and media blasted using glass beads. Polished the text/logos smooth and then applied a thin coat of high temp clear to make cleaning dirt off easier in the future.
Decided to do a retro fit hydraulic roller cam set up. Went with "Comp Cams 12-422-8 Xtreme Energy", and it was hard to find retro fit hydraulic lifters in stock anywhere, but I finally found some after calling different retailers.
ARP bolt fastener kit, full gasket kit, Speed Pro Hypereutectic pistons, msd cut to fit plug wire set, some very nice 304 stainless shorty headers from a guy at work, B&M 20404 torque converter (2400 stall) from Facebook, and some other odds and ends.
I've got everything put together and just waiting on pulling the 305 to transfer things over to the new motor like brackets and accessories and other odds and ends.
