Anyone have Digi-Tails LED lights?
I have them on mine as well, the setup should come with a digital flasher though.
What I’m talking about are LED bulbs that plug into the stock sockets. The Digi-Tails are basically purpose-built circuit panels that replace the stock bulb housings.
I'm the OP. The Digi-Tails lights, at least for the wagons, require you to cut out the stock bulb housings and create a flat surface to caulk the new circuit board with the LEDs to. There are LED bulbs that replace the stock incandescent bulbs, but for flashing applications (like turn signals) sometimes the bulbs require an inline resistor to prevent hyperflash. Some bulbs have a built-in resistor, and are usually quite a bit more expensive. Does that help clarify?
Hello CaliWagon83, what are you referring to in this post?
Yes it does. Thank you!
Those should be easy to source, I am pretty impressed with the bulb I bought to go into the third brake light. Once I had the Digi Tails installed I had thought about just doing strip lighting inside the housing for a custom look. May still do it since I have an extra set of tails but got plenty of other stuff I need to get done before looking into that.
Well I got my reply from Digi-tails. This is what the said about changing the direction of the turn signal flashing to side to side as in reprograming. their reply-
"No I'm sorry they can't. We would have to custom build a set to do that."
I sent another email off to ask what the cost would be. We'll see what the say.
Curious to see what they say, not really sure why they never set them up to go to the side in the first place. Only thing I can think of is it was cheaper and eaiser since there are less rows side to side rather than up and down to program.
