REGAL Best Place To Get Window Sweeps?
8,228
17,688
The ones with the silver bead on it are GM part numbers 20674278 and 20674279.
Black beaded numbers are GM part numbers 20674280 and 20674281.
These fits 81-88 Cutlass and 81-87 Regal ONLY. Montes are different because they don't have that flip up section in the front..
Obviously you can use the equivalents. Fairchild makes some but they seem a bit pricey.
bob64
713
678
Niagara Falls, Canada
I've got them from Rockauto for 86 olds, 78 elco, 86 Monty. The Olds comes with or without the chrome trim, l got with out an it worked fine, screws all lined up.
Nov 4, 2012
6,024
12,779
If there is any question, Fairchild makes good stuff. I used their door seals, window seals, window sweeps, and rear glass seal on my 95 F150 project and they fit better than the factory ones did.
6,836
6,749
The ones that come with the molding are the thin chrome bead, ones that come without are for the cars that have the wide chrome trim on top of the door.
8,228
17,688
For reference, 20672476 and 20672477 are the GM part numbers for the rubber seal strips that attach to the wide anodized aluminum door top molding. They're about half as wide as the ones with the beads.
