1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Best way to lower my el camino
Discussion in 'Chassis / Drivetrain / Suspension / Wheels' started by Crapple21, Feb 3, 2012.
Thread Status:
  1. Crapple21
    Crapple21 Greasemonkey
    Apr 16, 2011
    245
    16
    Washington
    Im going for the cheapest way to lower my el camino as me being a college student with not a lot of money. Just wondering what the best and cheapest way to do it. Any help is appreciated thanks
  2. jrm81bu
    jrm81bu Comic Book Super Hero
    Jul 9, 2008
    3,032
    50
    48
    Antwerp, OH
    Cheapest-Cut them.
    Best-Most likely spindles in front and lowering springs in rear.
  3. cdg1984
    cdg1984 Royal Smart Person
    Oct 18, 2009
    1,009
    2
    38
    Evansville IN
    cutting them will give you a bumpy ride. I highly recommend saving for a bit and getting some drop spindles.
  4. Crapple21
    Apr 16, 2011
    245
    16
    Washington
    I have read stuff about using f body springs? And that lowers it some but don't know how much work it is and what not to do that?
  5. hoodfellas1987
    hoodfellas1987 Not-quite-so-new-guy
    May 6, 2011
    12
    Chicago
    I've been researching all that stuff too bc I'm trying to do the same and the spindles in the front are about $200 and the springs for the rear roughly range from $75-175, and my conclusion so far has come to spindles in the front and lowering springs in the rear which is probably the best way to go and i have looked into the s10 springs which will lower it about 2 inches. As for me i think I'm going to go with eibach lowering springs all the way around bc i don't know if i wanna drop the front yet my concern as of know is the rear
  6. Crapple21
    Apr 16, 2011
    245
    16
    Washington
    What year springs from a s10 can you use and the front or rear? Because I don't necessarily want performance I just want low.
  7. drogg1
    drogg1 G-Body Guru
    Jan 25, 2009
    880
    67
    Nice El Camino. This page has good info on using fbody springs and s10 springs:
    http://jeffd.50megs.com/Moog_Spring_Page.htm
    Drop spindles give you a two inch drop and can be had for around 160 dollars + shipping.
    http://www.summitracing.com/parts/DJM-DS2031-2/
    s10's have the same front suspension as our cars so those will work.
    As far as whats best, easiest, etc., I wouldn't cut your springs. Besides that, replacing your front springs requires you remove the wheels, brakes, shocks, and popping loose at least one balljoint on each side in the front to get the springs out. This should be done with caution as the springs will shoot out and could hurt you if you are not careful. For the rear springs, you need to remove the shocks and raise the car while lowering the rearend until the spring is loose. These are not as dangerous and should fall right out.
    Here's some articles that might help you out:
    http://www.carcraft.com/techarticles/sw ... index.html
    http://www.superchevy.com/technical/cha ... index.html
  8. Crapple21
    Apr 16, 2011
    245
    16
    Washington
Loading...
Thread Status:
Share This Page
