The grit is determined by the type of rings, see what the ring manufacturers recommendation is. Cast iron is somewhere around 220 grit, moly coated somewhere in the middle and chrome moly rings can be as fine as 400 grit.
That line in that bore is trouble, what does the piston skirt look like?
The first picture looks like you slowed the rotation of the hone before removing it from the bore. Use a slow setting on the drill but it needs to be at full speed when inserting or removing the hone.
The cross hatch pattern is supposed to be 27-45 degrees, it is a factor of the drill speed and the speed you move the hone up and down in the bore. Experiment with it till it looks right.
I prefer the ball type hone. Less to get wrong.
