I started to do this swap years ago when it was still the hot setup. I had the spindles, C5 brakes, and the Global West upper arm. They sent me an arm for a stock spindle and I didn't know it until it was too late to return them. Fortunately I didn't get my car done and after some years found out why it's not such a good idea. Here's a quote from the
www.scandc.com website:
Q: Will SC&C’s SPC arms work with the B car spindle swap? What’s the difference between Street-Comp and the B swap?
A: Yes, our SPC arms will work with the taller B spindles. This swap requires a shorter upper arm so you just adjust the arms to fit and set the alignment. The B swap offers better than stock brakes and improves the camber curves and roll center height due to their taller overall height. That’s the good news, now for the bad news…the B spindles were designed for a totally different car. So while they can be bolted on, not everything lines up correctly. The steering arms are longer which slows the steering ratio and upsets the ackerman angle or the difference in the angles of the tires when you turn. Worse, it doubles the amount of bumpsteer, which isn’t too good to begin with! This can make the car feel very unnerving to drive, especially at speed. The B setup is also quite heavy and increases the track width of the car, which may lead to tire clearance problems with fenders.
You can get the bracket and bolt the C5 calipers onto your stock g-body spindle and use the stock a-arms.
www.flynbye.com If they aren't specifically listed you can email Ed. That's where I got mine. $75
SC&C has an adjustable upper arm that can be used with taller upper and lower ball joints and stock spindles for the needed improvements without the negative bumpsteer issues. I was told this setup gives a better front end geometry than a 2002 f-body setup.
