David Williamson said:The timing was good, I found out.
Its just the carb and something with the gears not engaging.
CHRIS.O said:What do you mean gears not engaging? Are you talking about timing gears?
DoubleV said:David Williamson said:The timing was good, I found out.
Are you 100% sure on that? Who did it and exactly how did they do it? What was the base timing set to?
Don't ever assume something is done right, because it usually isn't. You always need to verify. My friends 86 442 was 'fine', even though it ran 19's at the track. Checked timing and it was set to 0 but shoul've been at 20. So much for the timing being set 'properly' as she swore it was.
EDIT; I see you have a Chubby engine in your Cutlass, so your timing would be different.
What does this mean exactly?
Bonnewagon said:First off, if the carb is so old that the gaskets are shot and it looks like it was dipped in crud, then a total rebuild is in order anyway, just by opening it. But if it's looking clean, and the gaskets look solid and can be reused, then a cleaning won't cost you any more than a can of carb cleaner. A cleaning is just that, open her up, spray out all the passages, verify float setting, and put her back together. If it requires a kit, you can find rebuild kits cheap at RockAuto.com. A Q-jet has a few quirks that any Rochester book or internet tutorial will explain. And you did research Q-jet rebuilding, right? If not, or you are all thumbs, then don't bother, buy another carb.
pontiacgp said:see if there is a local guy who rebuilds the q-jets. You'll get a better carb if it's rebuilt by someone who knows them and it'll most likely be cheaper than a store rebuilt carb.
