Ahhhhhhhhh, I see what you mean now... Yes I need carb studs instead of the bolts...You could. But then if you put carburetor studs in the mounting holes, you can use whatever gaskets you wish without having to worry about bottoming out and stripping threads on the intake.
And to add they could be worked loose & get sucked into the intake to add other possible issues.PLEASE! JUST STOP!!!!!!!!!!!!!
Please stop with the jury-rigging ideas on fixing your car. Nobody worth their salt is going to condone it. It's one thing if you're going to hang a pair of fuzzy dice to it, but it's completely another when you're trying to fix all the issues for your car and getting it to run where you can confidently drive it. If you want help in getting rid of all the jury rigged crap on your car, dismiss the idea of adding to it. You keep wanting to continue to do damage to your intake threads instead of trying to fix it properly. That's just fruggin' nuts.
You don't have to use every suggestion everyone gives you, but if you're not going to properly fix that bolt hole, you're just pi$$ing in the wind. I don't want any more part of it. Good luck.
This isn't a simple repair you can do half assed, like leaking fluid for power steering for example.Found some subwoofer wiring I have laying around, I guess I'll give this copper wiring hack a shot and see how it turns out... View attachment 184486
