Cheapest way to get posi
okay ill ask if he hasnt sold it already he hasnt responded to me but he might be out of town with it being memorial day weekend. thanks for the info and was there a specific gbody that came with a posi more then others besides the gn, 442, ttype, or monte carlo ss or is it just hit and miss?
It's not even a guarantee in those models. And even in the ones that should have them, they may have been pirated.I've found them in lame-o Grandma cars but they usually had Granny gears too. At least in a sporty model you 'may' get a good ratio. But it's worth looking around, since by the time you buy a set of gears, a posi carrier, and have a competent shop set it up, you could have bought a great rear complete for far less. It's a lost skill setting up a rear, and worth knowing, but it must be done RIGHT or carnage will result.
What gears are in there now? I have a 2:78 posi and I cruise at 2000 rpm at 55 mph. I think 3:08 and 3:23 are good ratios, not bad on the highway, yet peppy on the street.
I have 308s on a 225-60-16 tire and I am glad I didn't go any lower (higher number) I drive 65-75 mph and I am usually around 3 grand. I have to get a better radiator just from going with 308s I used to run around 160 now I an around 180-190 on the highway. I wouldn't go over a 3.42 if you have a 3 speed and hit any highways.
With that pic I'd say no, because I can't see the clutches or spring/s. And on second look, it's a non-posi case, wrong shape for a posi. See the lip of the ring gear where it bolts to the carrier flange? The tooth counts should be stamped on that ring. Here is a picture of a posi case. Much different than what you are showing. Smells fishy to me.
