Agreed +1CHRIS.O said:You won't make 600hp with vortec heads. Honestly your build needs to be way more radical to make 600hp. Think stroked. 500 is more reasonable but still going to be a radical build and not pump gas friendly. The machinist should be able to design this engine for you. If he cannot then find another one. 500HP is going to take some nice heads and a more radical and efficient cam than the mother thumper. I would go for a custom grind from your favorite cam manufacturer. I would also go hydraulic or solid roller. As far as heads I would look into something from Dart or AFR. 190cc intake runner minimum. Dart Pro 1 or AFR Eliminator heads.
LilSpann601 said:How much nitrous can I run with the setup im running right now?
My rings are gapped about .025 if i choose not to run nitrous because of my lack of forged internals should I worry about oil-blow by??
