LilSpann601 said:Am I required to use a windage tray? I didn't even know they existed til I googled it. Im still trying to decide whether to use ARP Studs or Bolts? Whats the pro and cons of using them
If it is just a street engine then you do not need a windage tray. But since you need main fasteners anyways I would still go with the studs. They put less wear on the threads in your block and they have more accurate torque readings since there is less friction because only the nut turns on the washer when tightening vs a bolt threading into the block and the head of the bolt also turning on a washer at the same time. I think I explained that right.
