Coolant leak 1988 cutlass
angel84elco
Jan 8, 2014
94
78
Hello all! So this morning I started my olds up and when I reversed out the driveway after letting the car warm up I noticed a leak where the lower hose is. So I drove to the store and to my dads house and we noticed no leak and no overheating or loss of coolant in the reservoir tank.im thinking it is the hose. Your help is much appreciated.
MrSony
6,830
6,741
Des Moines, Iowa
Could just be loose. Keep an eye on the levels. Only other thing in that area would be the trans cooler built into the radiator.
angel84elco
Jan 8, 2014
94
78
For now I bought another hose going to let her cool down start her up again and see what happens. And your right and I checked that trans cooler line and it’s bone dry
MrSony
6,830
6,741
Des Moines, Iowa
make sure you have a big pan or something for the fluid. You can let it drain out of the hose you pull off or the petcock on the radiator. If its an older one, I wouldn't chance with the petcock if it looks rusty.
angel84elco
Jan 8, 2014
94
78
Yeah I’m putting a pan under neath gonna catch as much as possible
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I had that issue on my Jeep, it would leak once in a while from the lower hose, turned out to be a broken hose clamp.
Texas82GP
Just-a-worm
Apr 3, 2015
7,988
18,696
Spring, Texas
A loose hose clamp will allow a leak in cold weather.
angel84elco
Jan 8, 2014
94
78
I also found the water pump squealing so that’s being replaced as well as the belts
8,823
7,775
Melville,Saskatchewan
Make sure it isn't coming ftom the weep hole in the pump, looks like a leaking lower hose.
