Yeah, he didn't know what he was talking about. Bolts never come with sealed hub & bearing assemblies....
Based on the pics from 'xylorex', the CPP C5 spindles seem to just be a cast spindle w/the C5 hub.
There does not appear to be any drop when looking @ the hub centerline in relation to the lower BJ.
The steering arm seems in the same basic location as a previously posted OE/dropped style CPP spindle which does zero for the known factory bumpsteer problems.
I can't tell from the pics so w/o measuring there's no way to know if they're taller which would help the camber gain vs an OE based spindle/upright.
Any update on these spindles? It there a parts list out there that includes the backing plate you were missing?
Measurements would be cool. Upper BJ pad to lower BJ pad. I believe g-body stockers are around 9". Tall spindles usually are 10+. I have some C4 spindles I recall they were about ~11".i think everything is in the stock locations. it is not a dropped spindle.
i believe the camber gain you speak of is achieve with aftermarket control arms.
if you would like a measurement, and i can get it with the spindle installed --- let me know and i'll get it for you.
As far a control arms helping, they mainly contribute to caster gain. Some might have an agressive 'drop' where the upper BJ seats; those would seem to help. But, usually its a taller upright or tall BJ's that help camber gain.
The only way for control arms to alter bump steer is to alter their length. This would have a larger efffect on camber gain than bump steer though. There must be bump steer kits available to deal with that issue separately though, right? Are these going to be offered in a drop spindle as well? If not, then the S10 route seems better IMO unless there are geometry issues with those knuckles that I'm not aware of.
