Cruise Control Stalk Rating
81_El_Homewrecker
170
Hey guys - I want to use my cruise control stalk to run my TCC and my line lock. The stalk has three wires and I figured out how to my this work using a common fused power, then one output for TCC and one for the line lock. My only concern is the amperage that the little cruise control wires can handle. The TCC solenoid pulls 0.5A and the line lock is supposed to be fused for 4A. Neither would be on together, and the line lock only momentarily. I really hate to run a relay setup for something that is 4A and 0.5A...seems silly. Any insight appreciated!
69hurstolds
8,198
17,599
That's some pretty thin wiring. Super cheesy. It MAY hold 4A, but who knows. It should do .5 A momentarily no sweat I would imagine. Some of the electricians here who actually know electron flow would be better suited than I to answer about the 4A.
81_El_Homewrecker
170
The 0.5A would be for long periods of time, since it’s the TCC solenoid. I’ll see what other guys says but I guess I’ll probably end up adding relays even though it’s tiny amounts of current.
69hurstolds
8,198
17,599
Good luck on it. I'd choose relays just to be sure, because they're relatively cheap. Couldn't tell you the number of times I accidently let the smoke out of electrical components when I guessed wrong. :)
KCP
421
1,004
Bavaria, Germany
x2
Use relays and call it a day.
Texas82GP
Just-a-worm
Apr 3, 2015
7,988
18,696
Spring, Texas
flemming442 where are you?
