I drove it home on a dealer plate tonight. It needs shocks and deals like the TV cable needs adjustment. When I got home i was down to like 6V because it's not charging. But I must say I like it
5.9 Cummins is a good running/long lasting diesel engine. 6.2 is a turd that happens to burn diesel fuel and is semi reliable.What trans? The 6.2 is a good running and long lasting diesel.
I think it's a 700R4What trans? The 6.2 is a good running and long lasting diesel.
You forgot you need an aftermarket radio so you can hear it over those ungodly loud cement mixers that need to be turned off to go threw a drive throughYeah but when you have a Cummins you need an antidote to stop from rolling coal, and shouting "6 in a row built to tow" while you rattle away in your dodge designed 2 decades before with solid axles and chocking on exhaust fumes from the holes that enividably propopgate through the Swiss cheese floor pans in your 1st Gen Ram 😛
Word had it from my time at Deere engineering, GM and Deere had a joint venture on the Detroit diesel program in the 70's early 80's. Deere almost had a small 6 cyl turbo diesel for a square body and the GM/Deere relationship turned sour and it never happened.
Could you imagine in 1986 having the choice between a Deere powered Chev, IH powered Ford, or a Cummins Dodge? The Deere Chev would have dominated. Reliability and power of a Cummins with the body and chasis quality equal to Ford.
Two tone color it's going to look good you'll seePlease don't paint the wheels body color.
A lot issues than the 6.5 Turbo.5.9 Cummins is a good running/long lasting diesel engine. 6.2 is a turd that happens to burn diesel fuel and is semi reliable.
Thread lightly with that turd, never, I repeat never tow in O/D. The 3-4 clutch packs always head south. Adjust the TV cable, push the button on open the throttle by hand, should ratchet if out of adjustment.I think it's a 700R4
