Coolant level is slightly low (maybe a quart in the radiator and the reservoir is empty) but I just changed the water pump on Saturday and didn't put that many miles on it before I took it to the track so theres a good chance it just knocked a bubble out, I'm not condemning that yet
I don't own a leak down tester but I think I can put one together with the compression tester I have and some air compressor fittings.
My plan of attack is
1. Tap into the coolant system and put 10psi on the cooling system, see if It holds pressure, if not the head gasket might have popped
2. Put my dial indicator on the intake and exhaust lobes of the cam and see if I have full cam lift, it wouldn't surprise me if I wiped a lobe BUT it seems odd I wiped a lobe at the same time I had that excessive fuel problem
3. build leak down tester and see if I'm good. I am pretty sure there isn't an issue there since it made compression awesome but its a possibility
It would kinda make sense if it popped a head gasket since its burning cool but making some heat, but #4 would be the least likely to pop into a water jacket since there isn't a ton of water next to #4, #2 or #6 for sure, but #4 is the driest.
Also would make sense if it wiped a lobe since the cam was used and I haven't been putting zinc in the oil like I should have. Just odd it would have happened at the same time as this fuel issue.
I think the rotating assembly is solid for the good compression it made and I pulled the PCV off and revved it a bit with the oil fill cap off and there wasn't any noticeable blowby.
EDIT:
My "new" coil might be shot.
I did some reading and anything under 13k ohm is good, new is 11-11.5k ohm. I seem to remember the posts that im getting a cold burn on had 17k ohm and i didn't think anything of it since my old coil pack that was bad was open across two posts. I assumed open meant shot and any ohm reading was OK. I need to dig into that more.
I have some good LS heat sink coils on the shelf, these guys sell a low cost converter box that controls LS coils. This is the 2nd coil ive gotten that has "blown" so Im tempted to ditch it and go with something that's more robust. It will take some wiring but hopefully solve my problem.
https://www.dynamicefi.com/BuickIgnition.php
