Im not sure what section this belongs in but anyway I got a problem with my driver side window. The top is leaning too far in causing it to not seat right against the new weatherstripping. When the window is up all the way and I close the door it grips and pushes on the weatherstripping and the door wont close all the way unless I really push. Heres some pics
You can see the small nick where the window hits the trim as it closes.
This is where the front of the window sits on the weatherstripping when its not closed all the way. You have really push on the door for it to close all the way
When I compare it to the otherside, which closes and seats fine, I see that the top is bowed inward more. What can I do to fix this?
