I have a dual exhaust set up already complete with mufflers and cats i also have long tube headers and would like to know if anyone has pics of where to place hangers and where to buy them. Any help would be GREAT thanks a million
I purchashed the kit from the same year monte that was being gutted. Unfortuatly i did not take the time to look at the placement of the hangers. Can u help? Its straight pipesIs this a kit or something you made?
Who makes the kit? I'll have to snag a few pics tomorrow of my setupI purchashed the kit from the same year monte that was being gutted. Unfortuatly i did not take the time to look at the placement of the hangers. Can u help? Its straight pipes
I wish i knew. But i will lay my setup out in the garage tomorrow and also take pics. I do know its all 2.5 inch pipe all the way back. Thanks a million kwik.Who makes the kit? I'll have to snag a few pics tomorrow of my setup
Thanks I'll try itThe tailpipes look backwards (and switched left/right) to me. The mufflers will be under the rear footwells, so the short ends in the foreground of the last photo should bolt to the mufflers. I am not sure but I think you should try swapping the intermediate pipes (with the cats) left/right. And maybe flip them over. The pipe with the two small bends looks like it was made to fit under the driver's side of the transmission crossmember. The floor on the passenger front is higher than the driver to clear the OEM cat.
You could make your own hangers. If you can work with a torch, get some 1/4 or 3/8 rod stock at the hardware store. On the pipe side, make a small arc that matches the pipe curve, then put a 90-degree vertical bend, then a purpendicular bed (fore/aft) and bend the tip down one end. Make a matching bend with the tip up, then figure out where you want it, and flatten the the other end, drill two holes, and bolt on. Or, weld to the frame. Leave enough room for a donut you can get at the parts store. Looks like a rounded-ff diamond with a home in each end. That's how the OEM does it.
