ECU converter 200r4 lock up control
565bbchevy
565bbchevy
7,012
Michigan
Will the ECU still work to control the lock up function for the converter if everything else like dist, carb, emmisions etc. are disconnected just leaving the plug in the trans with power and ground, I am assuming it needs inputs to know when to lock up.
Clone TIE Pilot
Clone TIE Pilot
2,090
Galaxy far far away
No, the CCC system is an all or nothing system. You are better off leaving the CCC system intact.
TURNA
TURNA
9,793
Socialist NY
I bought this
The Painless Wiring one is a POS
pagrunt
pagrunt
4,986
Elderton, Pa
Square bodys with lock up trans use a vacuum switch on the engine tired into a stand alone harness that could work.
Reactions: TURNA
565bbchevy
565bbchevy
7,012
Michigan
I bought this
I already have the B & M above and am in the process of installing that now.
So do you have this installed already and how do you like it?
Did you have to go into the valve body?
TURNA
TURNA
9,793
Socialist NY
Its sitting in the back seat
Didnt look like you have to go into the valve body
565bbchevy
565bbchevy
7,012
Michigan
I just finished the under car part of the install and the wiring through my firewall looks long enough that you could probably mount the unit in the back seat.
I guess it would give you the option to mount it in the glovebox or something.
DoubleV
DoubleV
2,136
83
Medina Ohio
What's so bad about the Painless kit?
TURNA
TURNA
9,793
Socialist NY
I locks at 45mph and you just chug along.
Not meant to have fun with
The guys I know that have it put a switch in the line to turn it off and on.
O
oldsmobile joe
1,143
mpls
but the painless kit has the vacuum switch included to unlock the torque converter at part throttle. just like the pre-ecm factory design. i've used this style and was quite happy with it.
are people not using the vacuum switch?
