I don't have the cfm rating but something to keep in mind is that the majority of published cfm ratings for electric fans aren't even close to accurate.
A rule of thumb I found while researching fans is that for every 1000cfm of stated air flow, they should pull 10A. So if you have a fan that says it pulls 2800cfm but only draws 10A, odds are it probably doesn't really flow 2800 but closer to 1000cfm.
I had a Flex-a-lite Black Magic 2800cfm fan years ago the never could keep up with my 455.
Based on that I found this Derale setup:
http://www.summitracing.com/parts/DER-16927/
I've been using it on my 11.3:1 455 and it has no problems keeping the temps down.
A cheaper solution to is to use the dual electric fan setup out of an LT1 F-body.
