CHRIS.O said:
richp85elco,
Thats mighty nice of you. Glad to see people are still willing to help out for free.
David,
I am starting to wonder what the deal is too. I could of sworn you posted videos with it running smooth and idling. So what the hell happened? Obviously we are all trying to figure that out but I think we need to step back and start from the beginning. Did it always run this shitty? The smoke is not a good sign, neither is the clanking noise you said it was making. It seems like there could be multiple variables on contributing to it running like sh*t. If you have good wires and good plugs then I would eliminate an ignition miss. The black smoke usually means a rich condition. However if it just started then how in the hell did it tank its way to black smoke out of nowhere? Did it run worse or better after you adjusted the valves? I do not want to keep harping on that because I know ya said you did it right but they can be a b*tch to adjust sometimes. Especially if your engine is already out of tune with something else going on. Without being tthere I am kind of exhausted on ideas. All I can tell ya is hat IF it did run better before at any point then trace back to where it started running shitty and remember if you did anything before it started running bad. Thats a big if cuz I dunno if it ran well from when it was put in. Is the distributor locked down? Can you freely spin it? I dunno, I am out of ideas.
That's just it, I got it running perfectly with the help of you and few others.
But My mom called a guy over who has worked at gene's autos a little shop here in ky.
Well she called him because she thought I needed help, which I didn't I was making it run by myself.
So he comes over when I am not home, he goes into the garage without anyone knowing cause hes was supposed to fix a little piece in my alternator, he says it was bad or something.
But anyways hes goes into the garage and doesn't tell anyone hes there or knock on the door he just goes in my mom said he came to the door said he put the piece on and asked for the money my mom said she would give him for "fixing it" so she gave him the 35 to fix it.
Then says my battery is dead and he will go charge it on his charger, well that was 2 weeks ago, the day my car started acting like this and not wanting to stay started.
so whatever he did in the garage when no one knew he was there I believe he did something, he also stole my battery.
So he wont answer our calls, he wont call back.
There is so much to this story, just like the last guy i dealt with.
But you get the story so far.
So I have no idea what happened when it started to run like this.
But I am trying to check everything to see if he did anything, but I am just going off what I suspect or what i see out of ordinary.
But I mean i could have done the valves wrong, But like I said even before I touched them it was running crappy, then he came and now its running very crappy.
so I have no clue, But I will go out and video the noise.
The smoke I actually got to stop, i messed with the idle mixture screws and I saw no smoke after that.
But its still running weird, so I will go out and film it for you all and post it here in a bout the next 30 mins.
Freely? You mean if its off I can still turn it?
Cause I can freely turn it while the car is off yes.
