Re: engine problems, again. UPDATE!
It is running a bit better I have been out messing with all the idle screws and idle mixture screws its running a little more solid, but still backfiring if I push the gas.
I will upload a video in just a few to show you all I got it to idle perfectly at a 1000-1300 rpm.
But if I push on the gas even slightly it will backfire, sometimes in idle it will make a little backfire noise.
I have gotten all new wires set the plugs at .40.
set my idle mixture screws at about 1 1/2 turns, set my fast idle a little bit up.
Now shes at least staying started and running a bit better, just need to figure out why its backfiring and not wanting to go into gear and drive.
But again I will upload a couple videos of different angles.
There is also a clanking noise when I rev it up, i will also take a video of that.
