Usually a module is affected by heat. When originally introduced by GM, they suffered a shitload of warranty problems and even advised changing the module once a year just to be safe. What is was turned out to be a heat problem that killed the module. The fix was that it needed a heat sink, and that is why we now smear some dielectric silicone grease on the bottom of the module before screwing it down, so the heat can pass to the aluminum pad in the distributor that is sits on. Simple, eh? But they pulled their hair out in 75' and 76'. Symptoms were hard starting, rough running (when hot) and finally a no-start condition. Er,um, you guys DO smear that grease that comes packed with a new module on the bottom before installing it, right?
