Fast EZ-Efi Fuel Return Hook-Up
So you didn't just plumb it into the steel vapor line under hood? You ran it back to the tank? I'm trying to make sure I understand everything clearly here as I am Def planning on going the ez efi route. Any benefit to the steel braided? Also I'm guessing you left the stock lines in place for future use?
Nah I just ripped out all the old stuff. On my car someone did an engine swap before and had butchered the lines anyways. The only plus with going all braided is that its 3/8 line. Less restrictive. Plus its all new, now worries. I guess you could use the ones that are there but why both. Your under there anyways might as well go new.it's a beautiful kit. I love the way it works. Any other questions feel free to ask.
I gotcha. I have access to 20 more feet of push lock 6an, this would allow me to do the whole system correct? Any downside to losing your vent
Well you eliminating the charcoal canister anyways. I have yet to see a problem. I even talked to the guys at Fast and told them how I was running it and they said as long as I have a vented gas cap your good.
Any spit back when filling it up? Is an extra 20ft of 6an pushlock hose enough to plumb the whole system
Is the fast hose just rubber or fabric wrapped? I want all hoses to match
rubber with fabric wrap. Its a good quality hose. I wish it was stainless but I have all the fuel lines under the hood stainless except the return.
Ok cool, I think when its time I think I'm going to use the fragola series 8000 black fiber wrapped hose to finish off the fuel system.
Just an fyi, your likely going to get a lot of fuel vapor smell through that much non-hardline unless you use something like the Aeroquip ptfe braided line. Regular braided lines will let the fuel vapors seep through and will have your garage smelling like someone spilled gas.
really i have heard alot about it happening with some lines and not with the fragola stuff
