and here is the entire parts list he supplied me with:
1 30226 ECU, EZ-EFI WIDE-BAND CLOSED LOOP
1 170637 TACH ADAPTER ASSEMBLY, FAST
1 30271 CIG. PLUG-IN ADAPTER, FOR EZ-EFI
1 170407 ENCLOSURE,FAST A/F METER, EZ-EFI, EZ-TCU
1 170411 DISPLAY, FAST AIR/FUEL METER
1 170611 MEMBRANE SWITCH, FOR EZ-EFI
1 170632 PCB,HANDHELD FOR FAST EZ-EFI
1 30104 COMMUNICATION CABLE, 5 FT
1 30087 SENSOR, COOLANT TEMP
1 30278 BRASS BUSHING, 1/2"MPT X 3/8"FPT
1 170408 O2 SENSOR, BOSCH LSU4 WIDEBAND
1 30168 WELD IN 02 FITTING, FAST "NEW"
1 30169 02 SENSOR PLUG, FAST "NEW"
1 * 30227 HARNESS "ONLY", EZ EFI
1 30085 FUEL PUMP, FAST UNIVERSAL INLINE
1 30272 FUEL FILTER, -6AN BLACK
1 30253 FUEL FITTING, -3 SAE O-RING TO -6AN
1 30255 HARNESS, EZ-EFI FP RELAY
1 54027G FUEL PRESSURE GAUGE, FAST 0-100 PSI
1 30274 FITTING, AN6 TO AN6 FEMALE COUPLER
3 G3912 HOSE CLAMP, 12-20 MM 1/2-7/8
3 30275 FITTING, -6AN STRAIGHT PUSH LOCK END
2 30276 FITTING, -6AN 90DEG PUSH LOCK END
25 30277 HOSE, 1 FOOT OF #6 PUSH LOCK
1 304150MCAS MACHINING & ASSEMBLY COST FOR 304150
1 30158 TPS SENSOR, GM 91-95 LT1CAMARO/FIREBIRD
1 30086 SENSOR, AIR TEMP
1 307059 IAC MOTOR, FAST LS1
2 * 304150FR FUEL RAIL, FOR FAST-4150 TBI STYLE
4 54023B FITTING, LSX FUEL -8SAE O-RING TO -6AN
1 304150FRC FUEL RAIL CROSSOVER LINE, FOR 4150 TB
4 304150FRB SCREW, FOR 4150TB FUEL RAIL MOUNT
2 54015TPS SCREW, LSX THROTTLE BODY TPS MOUNTING
2 54015IAC SCREW, LSX THROTTLE BODY IAC MOUNTING
1 30254 MAP SENSOR, FAST 1 BAR, GM 16212460
1 82042 GASKET, ZEX SQUARE BORE CARB
4 30857 INJECTOR, FAST 87.8LB/HR 960.8CC/M
1 304150MMS SCREW, FOR 4150TB MAP SENSOR MOUNTING
2 170624 EPDM CAP, .375
2 170646 VACUUM CAP 3/16
6 30280 VACUUM HOSE, 3/16 1 FOOT
4 30258UL SS SCREW, STAINLESS 8-32X1/2" FOR 307030
1 30258JN SS JAM NUT, 3/8"-24 FOR 30258SS
1 30258W SS WASHER, 3/8" SAE FOR 307030 REGULATOR
1 30258SS SS SET SCREW W/ CUP POINT, 3/8-24 X 1"
1 30258UH UPPER ALUMINUM HOUSING, FOR 307030
1 30258SPR SPRING, FOR 307030 FUEL PSI REG.
1 30258LH LOWER ALUMINUM HOUSING, FOR 307030
1 30258NIP BRASS NIPPLE, 3/16" OD X 1/8" MALE PIPE
1 30258RB MOUNTING BRACKET, FOR 307030 REGULATOR
2 30258MBS SS SCREW, 8-32 X 3/8" FOR 30258RB
2 30258LW SS LOCK WASHER, #8 FOR 30258MBS
1 30258PP BRASS PORT PLUG, 1/8" NPT FOR 307030
1 30258SUB1 SUB-ASSEMBLY #1, FOR 307030
1 30258SUB2 SUB-ASSEMBLY #2, FOR 307030
2 30251 FITTING, -6AN TO STRIGHT O-RING -6AN
1 30273 PLUG PORT WITH SOCKET HEX O-RING, -6AN
1 NS6548 TIE STRAP, BLACK
3 30258BS SS SCREW, 10-16 X 5/8" FOR 30258RB
4 30291 SCREW, #12x1" LG.,SELF TAP,SS(FOR EZEFI)
15 30290 CORRUGATED LOOM, 15 FT FOR EZ-EFI KITS
