four questions
7,989
18,697
Now you know all you need to know about me
  • Love
doood
Amateur Mechanic
Sep 24, 2020
581
793
Looks good to me. Confirm that the gasket (o-ring) is contacting the DBC TB on all flat surfaces and you'll be fine.
You can plug whichever one you don't want to use with something like these :
These kits can be had cheap or use a piece of vacuum line on it with a 5/16" bolt sticking out of it. I don't think you're a 'bolt in the vacuum line' kinda guy though.
Am I right or wrong?
lol. I'm kind of on my own without you guys... so yeah, I am throwing money at things that a more experienced person would just stick a bolt in...
5,710
12,219
Just here to have some fun and help. Hopefully you're doing the same.
I get the feeling that you worry about alot of the little things. My advice, no need to worry - the worst that'll happen is you have to re-do something. The best part of what you're doing, putting an LS in your car, is the motors and parts are getting very reasonable to replace or repair, and they are really simple and easy to work on. They have become what the SBC was in '80's and '90's - lots of good available used parts and aftermarket parts readily available. To the point that people begin to dislike them. But the performance available from an LS is hard to argue with.
Good luck and never be scared to ask!
Jim
doood
Amateur Mechanic
Sep 24, 2020
581
793
Jim
Always wanted to build a V8
doood
Amateur Mechanic
Sep 24, 2020
581
793
Now I'm trying to graduate from my desk job to something more practically useful before this new generation outlaws gasoline along with gender.
5,710
12,219
If that happens, then we will be the next generation of moonshiners lol.
Wishful thinking on one side and scare tactics by the other side.
Never too late to learn and have fun. Just expect a couple of problems along the way. It's old school thinking that you, yes you, will have to solve your own issues.
BTW - what are you using for an operating system - factory ECU?
doood
Amateur Mechanic
Sep 24, 2020
581
793
I used gel type blue Loctite today on the flexplate bolts after I wire wheeled the old Loctite off the flexplate bolts. I should have just looked at the threads on the bolts after I removed them, they were full of blue crud. Additionally, I had no trouble torquing the crank Bolt to 140 degrees this morning. that is definitely not a torque to yield Bolt.
I am using the factory ECU but I purchased a new Factory ECU from "Psi conversion" in Brick New Jersey for $200 with the VAT disabled and some other things, but stock truck tune. I needed the new ECU because I have converted from DBW to DBC. I did not want to rip out my gas pedal and modify the electric pedal, because I don't know how to weld.
Another reason I'm buying all these things and trying to research solutions before I get to work is because I got little kids, full-time job, and got to fit the car project into a very busy life. often my time is worth more than buying overpriced conversion parts
thanks for all your input and encouragement
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Me too. At least you have the self discipline to work on one car at a time...
7,989
18,697
We used a PSI harness and PCM when we LS swapped my brother's 78 Z28. You'll be happy with what you bought.
doood
Amateur Mechanic
Sep 24, 2020
581
793
awesome.
Once I get this oil pan changed to the Holley 302-2, it's time to start disconnecting the old 3.8 liter from the car... going to take my time with that. Working in a shed is, well, better than working in a parking lot.
