Frame Paint?
I used Hammerite on a Jeep roll bar.
Sprays easy, last well.
I actually used some on my silver Tundra bedside where the paint was flaking from a previous repaint.
Hit it with a DA and 80 grit, and hosed on a few heavy coats from a rattle can.
Still looks OK after a salty Northeast winter, hasn't flaked, lifted or chipped.
Reactions: fleming442
You're right, it is pretty pricey.
I bought the material after putting in the work to clean the front of the frame.
After grinding on the frame for so long, the thought of saving $20 on material became less important.
With that, it is expensive all things considered.
I guess it all depends on how much you are painting and what equipment you have. It probably doesn't make sense to buy a compressor, air hose, filters, spray guns, etc. for a one time job or a small area.
It definitely looks like a quality product, just expensive.
I can't remember off hand the name but I bought some Rust Converter stuff from O'reilly's I am going to try it out when I get to the rust clean up; most of it being on the front end as it sits so low.
I will say this...if I had better ventilation and didn't have to worry about overspray, I would be spraying non-aersol paint with a compressor all day.
I had to spray my motor with a 6 gal. pancake compressor and it worked out well. I bought KBS motor motor so I could brush it on. It was metallic and after I bought it I found out I had to spray it so it forced my hand
With that said, my compressor and the $10 HF spray gun worked nice.
The gun is so cheap and it was so late when I finished that I didn't even waste the paint thinner cleaning up the gun....straight to the trash.
Checkout kbs coating it worked great for me
Haven't ran motor. I'm expecting the heads to discolor but have a good feeling the rest will stick.
Sandblast and Powdercoating will run less than $500, and will last a lifetime.
Are there any downsides to powdercoating your frame? I live 5 miles from you guys and that sounds like a good deal.
DOWNSIDE... You will want to clean the frame all the time.
Powder Coating
gives consumers, businesses, and industries one of the most economical, longest lasting, and most color-durable quality finishes available on virtually any type of metal.
Powder coated surfaces are more resistant to chipping, scratching, fading, and wearing than other finishes.
Reactions: GuysMonteSS
