As I recall a fusible link can be no longer then 6"
Im not sure if thats right. From what I remember the OEM links were a bit longer than that.
It looks really clean Nice Job on the setup and thanks for the good information.I'm not a fan of fusible links and did away with them. I also did away with the stock gang connection and separated all the wires into separately fused circuits.
Between doing that and needing some new wiring like going to dual electric radiator fans and headlight relays for my upgraded headlights, I installed a fuse block behind the overflow tank.
It's a Blue Sea Systems Safety Hub 150 and it's a very high quality piece and worked perfect for handling everything I needed.
The 4 bolt-down type fuses are MiDI-AMI type and I used time-delay for these. The 2 MIDI-AMI 40A fuses lead to the firewall connector and one leads to the ignition switch and the other to the main fuse panel. I upgraded the wire to 10GA from the stock 12GA for a little less voltage drop to the car's systems. The 2 MIDI-AMI 30A fuses are for my subwoofer amp and to power the radiator fans. You can also see that I used a 30A type 1 auto-reset breaker for the headlights. I also used 10GA wire from there to the relays.
I buy MIDI-AMI fuses from Waytek. By far the best selection and prices I've seen on these.
The power feed for the fuse block is a 4GA wire directly to the battery. The charging wire from the alternator goes directly to the battery also and is a 6GA. My battery is a dual terminal and I'm using both. The fuse block power feed and the charging wire go to the top post and the hot wire to the starter goes to the side post.
Maybe 7 or 8 but as I recall the length is very critical to the protection of the circuit. Been a long time but I think something to research
I finally dug everything out to take some pics of the maxi fuse box & cable. I even have some extra terminals I picked up at the stealership when I got it to add the right color wire for the circuits if I go with it. Painted the cover red just to ID it.Years back I picked up a small fuse box out of either a Grand Am or Cavalier (can't remember which & before joining here) that house seven MAXI's to see about replacing the links but wasn't shure how to properly go about it. I even got a '97 C/K positive cable to run to the drivers side for mounting.
is that a chevy are olds engine and where did you get the tube that you're running the starter wires threwThis is what it looks like. Both links go to the red 12GA wires to the bulkhead. At the time I couldnt find purple 12GA so I used the blue. I measured the original fusible link wire from the plastic barrel and made it the same length. Then I used uninsulated butt connectors, crimped them and covered them with marine shrink tubing. Think this is good enough ?
Im started to second guess what I did. Not good.
I need some help too. This is my situation and I don’t know how long or where to start wiring. The black cylinders have 16g on them.This is what it looks like. Both links go to the red 12GA wires to the bulkhead. At the time I couldnt find purple 12GA so I used the blue. I measured the original fusible link wire from the plastic barrel and made it the same length. Then I used uninsulated butt connectors, crimped them and covered them with marine shrink tubing. Think this is good enough ?
See post #25I need some help too. This is my situation and I don’t know how long or where to start wiring. The black cylinders have 16g on them.
