Gbody LS Swap Info
Does anybody have the part number for the small power steering pully that is needed to put in a gbody
Dorman 300-202 I believe. Just ordered mine today so I can report back as soon as it arrives.
Rock auto Cardone 3P15128.
  • Informative
Reactions: Injectedcutty
Ya that's the one I have but I am haveing a issue with it hiting the gear box so I guess I'll have to slide the motor back so it will clear
When you say stop truck accessories are you referring to the Tahoe and did you have any issues with the power steering pulley hitting the steering gear box
Yes. I used all the brackets, the stock PS pump, Alternator, water pump and crank pulley on mine. NO issue with clearance between the PS pump and steering box. It's snug but it clears
Ok awesome what did u do about transmission mount and drive shaft
O
Has a jegs th400 crossmember and a custom drive shaft w/1350 u joints from spohn performance
K I'm running the 4l60e so it may be different from yours my number is 9108184013 maby u could call me and give me some pointers lol
O
The 4l60e is unknow territory for me lol. Use 1" set back engine mounts and steer clear of the truck oil pan and the gm muscle car pan.... Both hang stupid low past the front cross member. The CTSV pan or a holley pan will be your best bet
