GNX2 Has Arrived(July 11, 2011 Update)
Re: GNX2 Has Arrived(May 12, 2011 Update)
gk666 said:
sex sex sex sex sex sex sex sex sex sex sex sex sex sex sex sex sex sex sex sex
if you put a caddy engine in it, theres a special place reserved for you in hell but..........
I would love to do the caddy engine but not really economical for me right now with funds. I am just going to build a turbo setup. I will run low boost on this motor until I get all the parts to build the bottom end up
I got my LED bulbs in today from HK. They came pretty quick. I sent payment on May 5 and received the 18th. I ordered these bulbs for the front because I will be going with the sequential tail lights for the rear. I am wondering do I need a flasher because the turn signal is flashing.
LED vs the originals
68 LEDs!
Two LED bulbs in
Re: GNX2 Has Arrived(May 18, 2011 Update)
I also ordered 3 sets of tweeters. A pair for the front, middle and back. Also on the way are LED dome light and Halo projector lights. I only ordered one set of the halo projector lights. I will order the other set next week along with the HID kit.
I don't know if I missed it or not, but did you ever determine what engine was in it? Was it originally a V8 car?
You got lucky that the engine appears to be OK. Good oil pressure? Is the brake system good?
I admire your ambition. Good job saving one from the crusher.
No I still havent determined what motor. I am leaning toward a 70's model 350 based off the exhaust manifolds and the fact that the engine is completely stock externally. Yea it seems like it runs fine. It has no knocking in the lower or higher rpm. I am not sure of the oil pressure yet. I havent gotten my gauges yet. Shoot I havent even moved the vehicle since the wrecker dropped it off at the house. Thanks.
Those led light are brutal bright . I have the spade style for the side marker light Bright as F#ck .
Re: GNX2 Has Arrived(Apr. 21, 2011)
kuruption109 said:
kingcolbert83 said:
Asa performance. His ebay name is abad71camaro
he is agood guy i bought some parts from him
I think he has a regular website. Its asaperformance.net but I havent checked it out yet.
My map light led came in today. Will get pics and video with the installed. Also have the gp front brace coming in. I am hoping to get my front suspension but together today.
